10 years agoHow to constrain a parallel bus from a PLL clock?
Hi. I have a couple of questions about the my design. Basically I have an FPGA which has a big data table which the values are readed and sent to an external DAC. The reading process and the DAC are ...
10 years agoHi Frank,
if the path M9k + multiplier path is to long for your 100MHz period you have to add pipeline stage in the middle. That could be a FPGA FF or FFs from the M9k or from the DSP Block. Dirk
