10 years agoHow to constrain a parallel bus from a PLL clock?
Hi. I have a couple of questions about the my design. Basically I have an FPGA which has a big data table which the values are readed and sent to an external DAC. The reading process and the DAC are ...
10 years agoHi Duesterberg,
Thank you for the information. Yes as you said I know the effort in hardware to make these types of operations. My question is how long is the delay to perform a multiplication for instance. Below I instantiate the ALT_MULT core with zero latency option. It seems that takes more 11nS to get the result. This mean I have to add an offset of 12 ns in the PLL output which gives the clock to the DAC ? Or if I use the latency options, I can't figure out how wait until get the result.
