11 years agoHow to connect my FIFO to mSGDMA inside Qsys?
I create my PCIe project based on Wiki's examples, removed the DDR3 and added FIFO inside Qsys. I can't connect my FIFOs to mSGDMA after i added them to my Qsys. I attached the project.
11 years agoHi Jerry,
sorry for the late answer. The Write-Master writes to your Host-Memory. It reads from your Fifo. The Read-Master reades from your Host-Memory. It writes to a (whatever) Data Sink. This is, why you have to connect the Output of your Fifo (Streaming source) to the Write-Master (Streaming sink). When you have a mismatch in data-width of write-master and fifo, you should correct this by editing the parameters of those cores. If you want to use a 256Bit fifo, you should also configure the write-master with a 256Bit fifo. At the moment the write-master fifo is 8Bit. Of course QSYS gives you this mismatch error. Just double click the write master and configure the data fifo to 256Bit.
