Artak
3 years agoHow to connect 32bit master to 8GB ddr memory using Qsys interconnect.
I'm using a board with Agilex FPGA and 8 GB DDR4 memory.
I'm trying to connect a 32bit AXI master (a soft cpu core) to DDR controller in Platform Designer. The Platform Designer interconnect autom...
- 3 years ago
I recommend the Address Span Extender component. It allows you to set a window into a larger memory space. The example given in the documentation is your use case:
For example, an HPS subsystem in an SoC device can address only 1 GB of an address span within the FPGA, using the HPS-to-FPGA bridge. The Address Span Extender enables the SoC device to address all the address space in the FPGA using multiple 1 GB windows.
AdzimZM_Altera
3 years agoI’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
