10 years agohow to code tan, arctan, log functions in verilog?
I need to use tan and arctan functions in verilog and generate a plot, one like in matlab. Also , the code should be synthesizable. Can any one suggest how can I code such trigonometric fu...
10 years agoOr just precompute the values you need to some resolution, and store them in a ROM lookup table using block RAM.
It all depends on what data format and resolution of computation you need (ie, 16b integer vs 32b floating point require dramatically different logic).
