CLiu18's avatar
CLiu18
8 years ago
How to check the RAM block overhead details?
My design consumes a lot more block RAM than I expected.
And I can not read the overhead from the OpenCL code. Is there any other way to get the RAM block overhead details so that I can which part consumes the block RAM?
By the way, I am using OpenCl 16.01
Cheng Liu
1 Reply
  • HRZ's avatar
    HRZ
    Consult the area report which includes line-by-line resource usage. I don't remember exactly but I think the area report for v16.0.x had to be generated manually. If you use newer versions of the compiler (16.1+), you will get a more detailed HTML report.
