Mahdi
5 years agoHow to change the origin of a region in Quartus chip_planner using command line
Is there any way to change the location/origin of the region in the logic lock region using command line instead of GUI?
- 5 years ago
Yes, you can refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-scripting.pdf
Basically, you look back to your *qsf files and you can write your own tcl file to set it. The target goal is to change the *qsf results .
KennyT_altera
5 years agoWe do not receive any response from you to the previous answer that we have provided. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
