Mahdi
5 years agoHow to change the origin of a region in Quartus chip_planner using command line
Is there any way to change the location/origin of the region in the logic lock region using command line instead of GUI?
- 5 years ago
Yes, you can refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-scripting.pdf
Basically, you look back to your *qsf files and you can write your own tcl file to set it. The target goal is to change the *qsf results .
KennyT_altera
5 years agoYes, you can refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-scripting.pdf
- Mahdi5 years ago
That works.
