10 years agoHow to change signaltap trigger using TCL
I am using tcl to capture signaltap data. The .stp file has a predefined trigger, based on a counter reaching a certain value. I want to capture data for different counter values. What I have so far:open_session -name $signaltap_file
run -hardware_name $usb_blaster -device_name $device -instance auto_signaltap_0 -data_log log_1 I am aware of the -trigger option for the run command, but I have no idea how to use it. Any ideas?1 Reply
- SBoda
Did you found the solution ?
