BHerr6
5 years agohow to change modelsim's default file browser.
Hello, I have been trying to get modelsim to work on my linux computer, but the modelsim is laggy and the fonts won't display correctly.
I'm using a Debian based distro. I wonder if there i...
Nurina
5 years agoHi,
The root cause for your problem is ModelSim Intel FPGA does not support your current OS: https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/os-support.html?elq_cid=7511234_ts1624241179952&erpm_id=10446625_ts1624241179952
Unfortunately you're going to have to live with that issue. This is not something engineering can fix since you use an unsupported OS. A possible workaround would be to use a remote desktop with a supported OS.
Apologies on the inconvenience.
Nurina
