BHerr6New Contributor5 years agohow to change modelsim's default file browser. Hello, I have been trying to get modelsim to work on my linux computer, but the modelsim is laggy and the fonts won't display correctly. I'm using a Debian based distro. I wonder if there i...Show More
NurinaRegular Contributor5 years agoHi,I'll report this problem to engineering. Can you let me know which OS you are using?Thanks,Nurina
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
