SYosh17
4 years agoHow to change "Latch Type" in Resource Property Editor
Hi all,
When I looked at the circuit I generated using the latch primitive in the Resource Property Editor, it consisted of LUTs instead of Programmable Registers, which I didn't expect. And the L...
ShengN_altera
4 years agoHi,
Probably can help you.
Note: In some cases, timing analysis does not completely model latch timing. As a best practice, avoid latches unless required by the design and you fully understand the impact.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
