GDeXi's avatar
GDeXi
6 years ago
How to bind pins for P tile PCIe
P tile Avalon-ST for PCIe IP Core have both rx_n_in and rx_p_in . Before, the binding difference should be taught to have only one pin . Now I confuse how to binding it.
,input wire rx_n_in0
,input wire rx_n_in1
,input wire rx_n_in2
,input wire rx_n_in3
,input wire rx_n_in4
,input wire rx_n_in5
,input wire rx_n_in6
,input wire rx_n_in7
,input wire rx_n_in8
,input wire rx_n_in9
,input wire rx_n_in10
,input wire rx_n_in11
,input wire rx_n_in12
,input wire rx_n_in13
,input wire rx_n_in14
,input wire rx_n_in15
,input wire rx_p_in0
,input wire rx_p_in1
,input wire rx_p_in2
,input wire rx_p_in3
,input wire rx_p_in4
,input wire rx_p_in5
,input wire rx_p_in6
,input wire rx_p_in7
,input wire rx_p_in8
,input wire rx_p_in9
,input wire rx_p_in10
,input wire rx_p_in11
,input wire rx_p_in12
,input wire rx_p_in13
,input wire rx_p_in14
,input wire rx_p_in15
,input wire tx_n_out0
,input wire tx_n_out1
,input wire tx_n_out2
,input wire tx_n_out3
,input wire tx_n_out4
,input wire tx_n_out5
,input wire tx_n_out6
,input wire tx_n_out7
,input wire tx_n_out8
,input wire tx_n_out9
,input wire tx_n_out10
,input wire tx_n_out11
,input wire tx_n_out12
,input wire tx_n_out13
,input wire tx_n_out14
,input wire tx_n_out15
,input wire tx_p_out0
,input wire tx_p_out1
,input wire tx_p_out2
,input wire tx_p_out3
,input wire tx_p_out4
,input wire tx_p_out5
,input wire tx_p_out6
,input wire tx_p_out7
,input wire tx_p_out8
,input wire tx_p_out9
,input wire tx_p_out10
,input wire tx_p_out11
,input wire tx_p_out12
,input wire tx_p_out13
,input wire tx_p_out14
,input wire tx_p_out15
Thanks a lot !!
  • BoonT_Intel's avatar
    BoonT_Intel
    Hello Sir,
    The serial output and serial input always some with differential pin. So, they should have "P" and "N" pins. For PCIe IP before P-tiles, the "N" pin is not generate at the PCIe IP top level. However, if you run full compilation. You can see fitter auto assign the "N" pin appended with (n) . You can find this info in the fitter report, under resource section, output/input pins. below is the screenshot for non-ptile PCIe fitter report.
    For P-tile, the "P" and "N" pins is declare at the PCIe IP top level, what you need to do is pull both "P" and "N" signal to your design top level. And you only need to take care about the "P" pin location like what you did for non-Ptile PCIe, then quartus will auto fit the "N" pin for you.
    • GDeXi's avatar
      GDeXi
      Thanks , thanks very much, I have figure it out.
      I was so stupid that I asked you this question, which brought you trouble.
        BoonT_Intel
        No problem đŸ˜„ Hope my answer here can help others user as well.
