19 years agoHow to avoid negative slack?
Hi, Currently i'm developing an SOPC also with some self developed components. I'm using QII-6.1 and the CyclonII-Nios-Eval board. Clock frequency is 85MHz. Looked fine so far, but during add...
19 years agoCould the problem be that one of your components has a chunk of combinational logic which is causing an excessive delay between two registers. In this case adding a multicycle assignment in the right place could help. This has worked for me before.
