19 years agoHow to avoid negative slack?
Hi, Currently i'm developing an SOPC also with some self developed components. I'm using QII-6.1 and the CyclonII-Nios-Eval board. Clock frequency is 85MHz. Looked fine so far, but during add...
19 years agoIf the clock is using global routing, it does not matter how many loads are on it.
Start with "Tools --> Advisors --> Timing Optimization Advisor --> Maximum Frequency (fmax)" in Quartus. If none of the recommendations in the Advisor solve your problem, then refer to the Quartus handbook in Volume 2, Section III, Chapter 8 "Area and Timing Optimization". If you still have timing violations after doing the basic things to improve fmax, then you might need to restructure your SOPC Builder system (for example, put some of the slaves on a bridge so that not everything is on one big Avalon bus).
