11 years agoHi Alex,
I solved the problem using two different ALTLVDS_TX. Using only one, you have to get all the outputs assigned on the same edge of the device. Unfortunately, the board is already finished and outputs can't be moved. We have two outputs on the TOP edge and three on the RIGHT edge. At least now the design fit the fpga. Thank you for the reply. Regards, Philippe
