11 years agoAre three of those pins in a bank with other I/O operating at a different voltage? Ensure all the I/O in the bank you're constraining your I/O to are 2.5V compatible.
Which device is it and which bank are you targeting? Are you targeting a bank that features true LVDS drives? I suspect you can place emulated LVDS drivers in these banks, but it's worth checking. If you remove all your I/O placement, does Quartus fit it? Always worth trying as a sanity check. Cheers, Alex
