gyuunyuu
Contributor
6 years agoHow to assign I/O standard of a pin only used with "Signal Probe" debug tool?
I assigned internal signals to pins on the FPGA by using the Signal Probe debug tool. I then saved the changes which runs the fitter. The fitter failed to fit route the requested signal the requested...
YuanLi_S_Intel
6 years agoHi Hassan,
Please find my response below:
- 3.3V I/O Standard is the default setting. User are encouraged to change the I/O standard setting on assignment editor or pin planner.
- & 3. Please assign I/O Standard on assignment editor or pin planner. After that, please recompile the design.
Thank You
