NuvKFC
Contributor
4 years agoHow to assign a pll clock to the dual-regional clock network
Some PLL clocks' loading is very light. So, I want to assign those PLL clocks to use the regional clock.
Unfortunately, the related regional clock assignments were ignored after compilation done as...
sstrell
4 years agoNo, not necessarily. It could mean that if those clock networks were used, the design would not be able to meet other requirements, such as meeting your timing requirements.
If you are seeing timing failures, you should investigate what those are related to and fix them.
Basically, if it ain't broke, don't fix it. If your design is working fine without using the dual regional clock, then there's no need to try to use them.
NuvKFC
Contributor
4 years agoHi sstrell
OK, I get it. Thank you, sstrell, very much.
