NuvKFC
Contributor
4 years agoHow to assign a pll clock to the dual-regional clock network
Some PLL clocks' loading is very light. So, I want to assign those PLL clocks to use the regional clock.
Unfortunately, the related regional clock assignments were ignored after compilation done as...
EngWei_O_Intel
4 years agoHi there
Can you check if you could use clock control block to achieve this?
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_altclock.pdf
thanks.
Eng Wei
NuvKFC
Contributor
4 years agoHi EngWei_O_Intel
Thank you, EngWei_O_Intel, very much. I will try it later. Could I just use assignment or other commands to meet it because the source code should be modified by RD?
