How to analyze the power of OpenCL code in Arria 10
Oh my god HRZ! I followed your comment try to use "quartus_pow", and get the results! It takes more than 8 minutes.
Warning (222013): Relative toggle rates could not be calculated because no clock domain could be identified for some nodes
Info (223001): Completed Vectorless Power Activity Estimation
Info (218000): Using Advanced I/O Power to simulate I/O buffers with the specified board trace model
Info (215049): Average toggle rate for this design is 25.123 millions of transitions / sec
Info (215031): Total thermal power estimate for the design is 27942.52 mW
Info: Quartus Prime Power Analyzer was successful. 0 errors, 96 warning
Info: Peak virtual memory: 14778 megabytes
Info: Processing ended: Sat Oct 20 01:52:26 2018
Info: Elapsed time: 00:08:18
Info: Total CPU time (on all processors): 00:27:38
Do you think this value is reasonable (27.9 W)? Seems a little high, isn't it? And it only shows total power, how to get the separate values such as dynamic, static, memory, I/0 powers? Many thanks.
