How to add top level generic into a Qsys system?
Sorry for any confusion. For your information, as I look into the qsys_system.vhd (which I believe is the top level of Qsys HDL file) inside folder qsys_system\synthesis\, I am able to find the generics for qsys_component as following. Would you mind to further elaborate on the specific generic that you are looking for if it is something different from the existing?
component qsys_component is
generic (
counter_max : integer := 15;
write_address : std_logic_vector(31 downto 0) := "00000000000000000000000000000000"
port (
clk : in std_logic := 'X'; -- clk
reset_n : in std_logic := 'X'; -- reset_n
avm_write : out std_logic; -- write
avm_write_data : out std_logic_vector(31 downto 0); -- writedata
avm_write_address : out std_logic_vector(7 downto 0); -- address
avm_wait_request : in std_logic := 'X' -- waitrequest
end component qsys_component
Chee Pin
- gyuunyuu7 years ago
Contributor
Dear cpchan, I want that the generics that exist on the qsys_component are exposed in the qsys_system. In other words, entity qsys_system is port ( clk_clk : in std_logic := '0'; -- clk.clk reset_reset_n : in std_logic := '0' -- reset.reset_n ); end entity qsys_system; Should become: entity qsys_system is generic ( counter_max : integer := 15; write_address : std_logic_vector(31 downto 0) := "00000000000000000000000000000000" ); port ( clk_clk : in std_logic := '0'; -- clk.clk reset_reset_n : in std_logic := '0' -- reset.reset_n ); end entity qsys_system; In this way, I can access and change the generic passed to the componet when I instantiate the Qsys system in my VHDL RTL code. Is the question clear now? Regards, Hassan Iqbal
