11 years agoHow to Add Library Path for Modelsim Altera Starter Edition 10.3d Gate Level Simution
Hello, I'm having problem running gate level simulation using Modelsim Altera Starter Edition 10.3d due to missing design unit: # ** Error: (vsim-3033) PWM_Gen.vo(670): Instantiation of '...
11 years agoI had a similar problem in which I have been getting error# ** error: (vsim-3033) alstimschem.vo(825): instantiation of 'altera_pll_reconfig_tasks' failed. the design unit was not found. when I have run ModelSim-Altera Starter Edition. I wanted to share details of the problem and solution with the Forum.
I am using schematic entry to create my schematic (.bdf file). I found that I could simulate the program with no problems when I used MegaWizard to create components LPM_MUX, LPM_MULT and LPM_ADD. But when I used MegaWizard to create ALTPLL, Altera_pll or ROM:1-PORT components, I would get the above error messagee for the PLLs when I simulate. If I disconnected the PLL's, simulation of the program with the ROM:1-Port would give# ** error: (vsim-3033) nofile(37): instantiation of 'generic_m10k' failed. the design unit was not found. I tried adding directories using Tools/Options/Libraries. I tried copying folders and files to folders that I knew the Quartus II and ModelSim was linking to. None of that worked. It is worth mentioning that I could download the program into my Cyclone V Starter Kit and everything would run as programmed. The only problem was with the simulation. the problem went away when i upgraded my quartus ii web edition from v13.1.0 to v15.0.0. (I did that upgrade a couple of weeks ago. But my compile times were going from 52 seconds to 1 min 11 seconds; therefore I switch back to V13.1.0. Looks like I'm stuck with the slower compile times if I want to simulate. And yes I have the Assignments/Settings/Compiler Settings configured for fastest compiling.)
