11 years agoHow to Add Library Path for Modelsim Altera Starter Edition 10.3d Gate Level Simution
Hello, I'm having problem running gate level simulation using Modelsim Altera Starter Edition 10.3d due to missing design unit: # ** Error: (vsim-3033) PWM_Gen.vo(670): Instantiation of '...
11 years agoRemove the curly brackets "{}" from around PWM_Gen.vo and add another line:
run -all Whether 'PWM_Gen.vo' is the right file or not depends on whether there is any test stimulus in it. If it's just your top level design then no, it's not going to do much. Typically, I generate test stimulus in a separate 'PWM_Gen_tb.v' file in which the top level module is also instantiated. So, you'd end up passing 'PWM_Gen_tb.v' to the 'vsim' command. Cheers, Alex
