11 years agoHow to Add Library Path for Modelsim Altera Starter Edition 10.3d Gate Level Simution
Hello, I'm having problem running gate level simulation using Modelsim Altera Starter Edition 10.3d due to missing design unit: # ** Error: (vsim-3033) PWM_Gen.vo(670): Instantiation of '...
11 years agoThanks Alex for your help.
I've managed to run through without the "design unit was not found" error anymore :) However, I'm still not sure about which file to use as test-bench. Here's the do file that I've edited: http://www.alteraforum.com/forum/attachment.php?attachmentid=10695&stc=1 And here's the screenshot of the list of files inside ..\QuartusII\simulation\modelsim folder: http://www.alteraforum.com/forum/attachment.php?attachmentid=10696&stc=1 FYI, the top design unit name is PWM_Gen. Should I use the PWM_Gen.vo as testbench? Or should I use the testbench file that I've used for RTL description simulation? The reason I ask is that when I run the do file above, only the PWM_Gen.vo text file opened & no simulation is running. Did I miss some command lines in the do file to run the gate level simulation?
