15 years agoI think, it would be easier to incorporate these signals if the design was sequential instead of combinational. It would also make it easier for me to calculate the latency of the module.
Converting the design to sequential, I'm using a 2 bit shift register 'tmp' to calculate the 'valid_out' signal which goes high on the next clock cycle after the 'valid_in' signal. What do you think about this code? module xorcomp( input clk, input [31:0] a, input [31:0] b, input [31:0] c, input valid_in, output valid_out ); reg [31:0] a_reg; reg [31:0] b_reg; reg [1:0] tmp; //the 2 bit shift register wire [31:0] a_wire; /*wires to copy the latched values of a, b, and c from registers a_reg, b_reg, c_reg*/ wire [31:0] b_wire; wire [31:0] c_wire; always @(posedge clk) begin if(valid_in=='1') begin a_reg<=a; b_reg<=b; c_reg<=c; tmp<=2'b01; end else tmp<=tmp<<1; end assign valid_out=tmp[1]; assign a_wire=a_reg; assign b_wire=b_reg; assign c_wire=c_reg; xor u1(out1,a_wire,b_wire); xor u2(out2,out1,c_wire); assign d=out2; endmodule
