how to add a file to library "work"
Error (10481): VHDL Use Clause error at sha3.vhd(13): design library "work" does not contain primary unit "keccak_globals"
This is my error
I have the file keccak_globals but I don't know how to add it to library "work"
- sstrell
You don't normally need to do this. As long as the design file is part of your Quartus project, you shouldn't have to reference the work directory. Try just removing lines 12-13 from your code.
Is "keccak_globals" in some other design file?
- ahmedhs
thank you so much your answer was enough
I didn't understand that you have to move the file to the Quartus project as I'm new to this
now everything works fine
- RichardT_altera
With sstrell help, I’m glad that your question has been addressed
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
