ahmedhs
4 years agohow to add a file to library "work"
Error (10481): VHDL Use Clause error at sha3.vhd(13): design library "work" does not contain primary unit "keccak_globals"
This is my error
I have the file keccak_globals but I don't know how to ...
sstrell
4 years agoYou don't normally need to do this. As long as the design file is part of your Quartus project, you shouldn't have to reference the work directory. Try just removing lines 12-13 from your code.
Is "keccak_globals" in some other design file?
- ahmedhs4 years ago
thank you so much your answer was enough
I didn't understand that you have to move the file to the Quartus project as I'm new to this
now everything works fine
