How does Quartus know what is voltage on each FPGA I/O bank?
- 5 years ago
To New Contributor I,
In the Pin Planner you specify what voltage goes to each I/O bank. This is done on a pin-by-pin basis. It will give you a (compilation) error if you specify pins with two different voltages on the same bank. It's up to you to connect the correct voltage to each I/O bank on your circuit board.
The video that I shared with you is just an overview of how Chip Planner work on Intel Quartus software. We have a lot of selections of FPGAs and different I/O Standards thus Quartus show a lot of I/O standards options. However, you can only set specifications based on I/O Standards that you pick on your design or else you will receive errors. To answer your question, the valid input is what the FPGA pins can handle on the specified I/O Standards. I hope this answer your question.
Thank you.
- AminT_Intel5 years ago
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
