How does Quartus know what is voltage on each FPGA I/O bank?
- 5 years ago
To New Contributor I,
In the Pin Planner you specify what voltage goes to each I/O bank. This is done on a pin-by-pin basis. It will give you a (compilation) error if you specify pins with two different voltages on the same bank. It's up to you to connect the correct voltage to each I/O bank on your circuit board.
Please check the attached image. It shows the available options for the pin I/O standards. The options are all over the place.
If Quartus knew that my I/O bank was lets say at 3.3V, it won't show me all those 1.0V and 2.5V options in the drop down menu. Do you understand my question now?
If you select an invalid I/O standard voltage for your device, you'll get an error during compilation.
- gyuunyuu5 years ago
Contributor
How does it know if it is invalid? I never told it what voltage supply I connected to the bank to begin with.
There is no option where we can specify what voltage supply is connected per bank on the FPGA.
None.
- AminT_Intel5 years ago
It will be invalid if your setting does not meet the specifications of the device. We have a lot of tutorial videos about using Quartus on our Intel FPGA Youtube channel. Here is the video about Chip Planner in Quartus Prime Pro Software: https://www.youtube.com/watch?v=Bt-yDRReKZw
Is all of your questions addressed? I will need to close this case if there is no update from you in 3 days.
Contributor
Please clarify what part of the video are referring to in your previous message. Also, is a valid input simply what the FPGA pins can handle or what is actually a function of the bank voltage? If the I/O bank is supplied by 3.3V supply then the pin planner should not even show the option to specify a 1.8V I/O standard for any pin on it. I don't think this is how pin planner works.
