12 years agoHow do you launch "Memory Test" in Nios ii EDS command shell
Hello, I'm trying to get the CFI interface to the Flash chip on the Altera cylone III development board working and I'm stuck because I'm unable to talk to the flash chip (or at least that is w...
11 years agoHey guys.. I'm trying to execute a memory test template using nios 2. It is getting executed but I don't know what name i should give after selecting the CFI flash. I tries giving "/dev/cfi_flash_o" which is the flash that I have generated using sopc builder.
I'm stuck here. please tell me what name i should give so that the cfi flash test runs successfully. Thanks in advance!
