11 years agoHow do I split a bus into individual signal lines?
I have a schematic that is supposed to take a 4 bit bus and then split off the individual lines into TTL logic. I created a 4 bit bus pin "in[3..0]" then connected a bus line. Then connected indivi...
11 years agoThe poor instructions probably come from the fact the schematics editors are not used very much. As soon as you have a design with any complexity, anyone would recomend you use a pure HDL approach (its easier to put in a version control tool and easier to testbench).
