11 years agoHow do I split a bus into individual signal lines?
I have a schematic that is supposed to take a 4 bit bus and then split off the individual lines into TTL logic. I created a 4 bit bus pin "in[3..0]" then connected a bus line. Then connected indivi...
11 years agoThanks. That seemed to work. Its just not very intuitive the way they do it like that. The help files sent me all over the place looking for a secret icon to click so I could bring up the node name editor.
It looks good on the screen, but it will be a few days before I can connect everything well enough to compile it to see if it actually works. I will post the results then.
