13 years ago --- Quote Start --- I assume you mean.. # Print the list of JTAG commands (commands prefixed with jtag) tcl> info commands jtag* jtag idcode jtag pulse nconfig jtag read jtag node id jtag node is bytestream jtag open jtag resetrequest jtag write jtag node is master jtag send jtag print hub info jtag close jtag usercode jtag print node info jtag number of nodes --- Quote End --- Yep, that's the software API to toggle it. You can also issue JTAG low-level commands to get to the register that toggles it. The protocol and testbenches are here http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.pdf http://www.ovro.caltech.edu/~dwh/correlator/pdf/altera_jtag_to_avalon_analysis.zip I'm pretty sure the Tcl script with one of those tutorials has a command that toggles the reset line - it may use the jtag resetrequest command directly. Cheers, Dave
