How do I merge the floating license X of Quartus II managed by server A into the floating license Y of Quartus II managed by server B?
I added the contents of the license file for X with the host ID changed to B to the license file for Y, but it didn't work.
- AR_A_Intel
Hello
Welcome to INTEL forum. It is not recommended to combine/merge Intel license.dat file as this act will corrupted the license.dat file. Some feature may work, and others may not.
We suggest that you regenerate the license file in Self-Service licensing center (SSLC) https://fpgasupport.intel.com/Licensing/license/index.html
- Tanaka02
Thank you for being late.
I cannot access the license center for some reason now, so I would like to check it as soon as I can.
- AR_A_Intel
May i know why, and could you provide the error message that reported?
- Tanaka02
I am now able to sign in to the License Center. Thank you.
How do I regenerate a license file?
1.Quartus II SE Floating / to 10/31/2020 / computerName / 1 License / manager-me
2.Quartus II SE Floating / to 10/31/2020 / mac-address / 1 License / manager-another
a.The computerName in 1 and mac-address in 2 are from the same PC.
b.I would like to run licenses 1 and 2 on one PC. Can I merge and generate a license file for two licenses?
c.If not, can I run two license files for the same tool on a single PC?
- Tanaka02
Sorry for the late response.
I am no longer in charge of the license server.
As far as I can remember, I contacted Intel support directly to create and send the merged license.
I'm sorry I can't be of much help.
- AR_A_Intel
Hi Sir
For license generation you can refer here https://www.intel.com/content/dam/www/programmable/us/en/pdfs/education/demonstrations/online/licensing/how-to-create-a-new-license.pdf
for more you can refer Self-Service Licensing Demonstrations https://www.intel.com/content/www/us/en/programmable/support/training/demonstrations/online/licensing/onl-licensing.html
- StefMon
I'm very sorry for hijacking an old subject, but I have the exact same issue, and could not find a satisfying answer to the problem. We also have two licenses administered by two different people that we need to merge, or at least run on the same server, is there a way (official or unofficial) to do this? or to merge our licensing accounts to generate a new file? Or at the very least a phone number to call?
- AR_A_Intel
Hi StefMon
This case is duplicate from forum # 04995401 on the same request. Therefore, I’m suggest closing this Case and continue with Case# 04995401
