How do I make modelsim fwrite/dump an 8 bit array literally in binary.
I'm having trouble finding the right way to dump a memory array from my System Verilog testbench into a file. This is as close as I can get, but, it has 2 problems.
Anytime I try to write character 8'h00, it gets replaced with character 8'h20.
Anytime I try to write character 8'h0A, 2 characters come out, first 8'h0D, then 8'h0A.
Code:
integer fout_pointer;
fout_pointer= $fopen("test_file.bin","w");
for (int i=0;i<256;i++) $fwrite(fout_pointer,"%s",8'(i)) ;
$fclose(fout_pointer);
This code is supposed to generate a file where if I analyze it with a hex editor, it should go from 8'h00 the 8'hFF. But, the 8'h00 position has an 8'h20 and the 8'h0A position has a 8'h0D, then the 8'h0A comes next.
Or, if I made an array:
logic [7:0] array_table [0:255] = '{8'h00, 8'h01, 8'h03, ..... };
Is there a way to binary dump/write that array into a file. And I do not mean an ascii file with binary or hex values in it.
Hello SyafieqS, thank you for your reply, but, your link does not cover any binary writing of data. It is ok as I fround out how and finally got my testbench SystemVerilog .bmp picture saver working.
Source example located here: https://www.eevblog.com/forum/fpga/systemverilog-example-testbench-which-saves-a-bmp-picture-and-executes-a-script/msg3448860/#msg3448860
Instruction are located in the first post in that thread.
The relevant code is in the source file 'ellipse_generator_tb.sv' line 203, opening the file for write as a 'wb' for write binary. And when $fwrite data, the two possible in quotes methods are "%c" for a single character, or "%u" for writing a 32bit word located on lines 215, 218 & 225.
- SyafieqS
Hi Brian,
I found refence related to read and write to file using SV and few examples that might be helpful. Please refer to link below for details
- BrianHG
