11 years agoHow do I infer dffe instead of mux
Hi, I am having a problem getting quartus to synthesize part of my design as a dffe register when the output of the register is fed to another module. If I run the following code (without a su...
11 years agoThanks tcworld, you are right, the technology map viewer does show that is has not used any muxes.
https://www.alteraforum.com/forum/attachment.php?attachmentid=10890 But in a complex design it is not very human readable. :-( I recently taught myself Verilog after many years of using schematic entry, so I have been using the RLT viewer to check my coding to ensure it produced an efficient design. But then I wasn’t seeing what I expected and thought my coding was at fault. Thanks for your help.
