Altera_ForumHonored Contributor14 years agoHow do I disable setup/hold violation errors? I'm simulating a design with ModelSim-Altera. The design has two clock domains and I'm using two-stage synchronizers on data that crosses between the clock domains. Because the two clocks are close i...Show More
Recent Discussionshow to reduce clock skew between synchronous clockQuartus 13.1 including Signal Tap LicenseI do not get an eMail with the generated license fileInstaller cannot establish connection with SSL errorQuartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SG
