Altera_ForumHonored Contributor14 years agoHow do I disable setup/hold violation errors? I'm simulating a design with ModelSim-Altera. The design has two clock domains and I'm using two-stage synchronizers on data that crosses between the clock domains. Because the two clocks are close i...Show More
Recent Discussionsstarting to learn FPGAsqsys-generate outputs Info as ErrorTiming analysis - long combinational pathQuartus Prime Lite 25.1 License Error - "Unable to checkout a license" (SALT_LICENSE_SERVER)Regarding the issue of UFM not starting
