How do I connect my CDPLK pin to the GCLK without the use of a clock control block in quartus ?
- 5 years ago
Hi Aaron
You are right. Clock control blocks that have inputs driven by dual-purpose clock I/O pins are not able to drive PLL inputs, which is the behavior of the CDPCLK pin. The PLL IP will not be able to take the CDPCLK as reference clock. PLL should always take clock input pin or GCLK driven by clock input pin as reference clock.
Eng Wei
Can you post the link to the thread. I am unable to find any similar thread. Thanks
Hi Aaron
Eng Wei
