How do i actually edit a schematic logic symbol ???
What you can do is use an 8-input AND gate and 2-input AND gate and use the outputs of both gates as inputs for a 2-input AND gate in one bdf file. After saving this bdf file go to File->Create/Update->Create Symbol Files for Current File
Then you have successfully created a new symbol. You can find this symbol in the symbol libraries under "Project".
Nurina
Hi Nurina,
Thanks, what i did was wire 2x "or8" gates into a "or2", making a 16 input or gate.
It took me a while to realise i had to add in/out pins to the gates and label them etc. (because my first symbol was an empty box).
Then i discovered after creating the symbol file that i also had to create a verilog file too. (i learned this from somebody's online school project).
Are there intel links to this information please?
- OldMarty5 years ago
Hi again,
I also noticed that i can only use primitive devices to make my own symbol files. If i use simple and,or,not gates it works, but if i decide to include any of the 74xx chips into the symbol design then there are errors and it wont compile.
Is there a way to use the 74xx chips in my symbol file?, or is there a way to view the internal primitives of the 74xx chip to let me cut & paste into my own design file?
Thank you.
