NuvKFC
Contributor
4 years agoHow constraint the output delay from the different clock edge to the same pad?
I get a ASIC design. And the path structure as follows.
Clock_a -----> IP1 use positive edge of Clock_a ------------> Pad_a: always capture the data on the
SyafieqS
4 years agoHi KFc,
Are you able to constraint the output delay?
NuvKFC
Contributor
4 years agoHi SyafieqS_Intel
My method is as follows constraints. I create two virtual clock for the out pin. Then set different output delay for those virtual clock on the output pin. And add false constraint to disable non-exist path.
create V1 -period 20 -waveform [0 10]
create V2 -period 10 -waveform [0 5]
set_output_delay -max 10 -clock V1 [get_ports Pad_a]
set_output_delay -min 0.0 -clock V1 [get_ports Pad_a]
set_output_delay -max 5.0 -clock V2 [get_ports Pad_a]
set_output_delay -min 0.0 -clock V2 [get_ports Pad_a]
set_false_path -from [get_clocks Clock_a] -through IP1 to [get_clocks V2]
set_false_path -from [get_clocks Clock_a] -through IP2 to [get_clocks V1]
