15 years ago --- Quote Start --- If you can afford a fund, you should buy ModelSim SE/PE in order to perform mixed language simulation, but if you can't then you have to write your testbench in same language with your IP like I said before, or you can find another IP written in same language with your testbench,.. I hope it can help you,... --- Quote End --- Thanks. I have made it in ModelSim SE.
