15 years ago --- Quote Start --- I think ModelSim-Altera doesn't support mixed language simulation. you can check it here : http://www.altera.com/products/software/quartus-ii/modelsim/qts-modelsim-index.html you need to write you testbench in same language with your IP. --- Quote End --- Thanks for the reply. ModelSim-Altera doesn't support mixed language simulation, but ModelSim SE support. What should I do?
