hsin0303
7 years agoHow can i see the waveform?
I want to use the opencl to design the FPGA. The OS is CentOS 7.4. I have already install the Modelsim and read the programming guide. When i used the command 'aoc -march=simulator -ghdl -board=pa...
- 7 years ago
What version of Quartus/AOC are you using? This option is only available in the newer versions of the compiler (I think 18.0+). Also note that based on the documentation, this feature is for simulating OpenCL libraries; you cannot simulate standard OpenCL kernels with this. You can emulate standard OpenCL kernels using -march=emulator but that is only functional simulation (not timing-accurate).
HRZ
7 years agoThere is no standard way provided by Intel to do that as far as I know. You might be able to do it manually by loading the OpenCL project in Quartus and creating test-benches yourself for all the signals involved.
hsin0303
7 years agoThanks for your advice.
