How can i see the waveform?
- 7 years ago
What version of Quartus/AOC are you using? This option is only available in the newer versions of the compiler (I think 18.0+). Also note that based on the documentation, this feature is for simulating OpenCL libraries; you cannot simulate standard OpenCL kernels with this. You can emulate standard OpenCL kernels using -march=emulator but that is only functional simulation (not timing-accurate).
- hsin03037 years ago
Thanks for your reply.
The version is Intel(R) FPGA SDK for OpenCL(TM), Version 17.1.1 Build 273.
Because it is necessary to observe the signal in detail.
Does it have any other way to see the waveform of the kernel?
