YaGaRa12New Contributor7 years agoHow can I pick some bits from bus in Quartus? Hi, I'm trying to select a part of the bus, from the output "Salida_alu" which is 32 bits [31..0], I am only interested in 4 bits [3..0] to enter them in the Func input. I have done it in several way...Show Morealu.png28 KB
Vicky1Regular Contributor7 years agoHi,Have you resolved the issue?Shall I consider the case to be closed?Regards,Vicky
Recent DiscussionsHow can I use Quartus Pro 25.1 sopc-create-header-files tool to generate a jtag master header file?Quartus Prime DownloadPlease, do not release another version of Quartus until you fix the file length problem in windowsQuesta - license problemRemote Update IP Support for Generic Serial Flash Interface on Cyclone V?
