YaGaRa12
7 years agoHow can I pick some bits from bus in Quartus?
Hi, I'm trying to select a part of the bus, from the output "Salida_alu" which is 32 bits [31..0], I am only interested in 4 bits [3..0] to enter them in the Func input. I have done it in several way...
Vicky1
7 years agoHi Ray,
I appreciate your efforts & patience.
just perform the following steps,
- draw one line using "Orthogoanl Bus Tool" in .bdf file & name it as Salida_alu[3..0].
- Then connect one end of Salida_alu[3..0] to the bus line" Entrada_Fun_alu2[3..0]" as shown in below screenshot.
let me know if this has helped to you or if you have any different concern.
Vicky
