10 years agoHow can i get the frame rate by the frame count in the CCD capture
Excuse me , i want to know how to get the frame rate Frame count means the all frame you have got in the time? but i don't know the time value i use signal taps to get the frame count value , ...
10 years agoHi Russ -
Can you re-word your question? I'm not sure what you're asking. What are you trying to do? And what frame count are you referring to? As you said at the end of your post, the MT9M011 data sheet tells you how to determine the frame rate if that's all you need to do.
