10 years agoHow can I generate time limited sof file?
Hi, My design is not uses cores without licence, but I need to generate "time limited" file to demonstrate. Can I do it?
10 years agoDoesn't a design run for like an hour if you have an IP that requires a license? I'm not sure but if that's the case. Could you just add the IP without "using" it?
